Training, Certification & Career
Trusted Contributor I
6.1 study guide - even questions
as mentioned before the 6.1 study guide only provides the answers for the odd questions, kevin said it was fine to discuss the even answers so here we go. if you don't agree with my answer post it here and provide some reasoning please
2. Which statement is true about the Content Security License?
A.  Applied to the master controller
B.  Applied to all the controllers in the network
C.  It is based on number of users
D.  It is based on number of APs
my answer: C - not sure where you put it, but certainly based on number of users
4.  Which tunnel protocol is used between controllers to support
Layer 2 mobility in an Aruba environment?
A.  Basic IP
B.  GRE
C.  IPinIP
D.  Mobile IP
E.  None of the above
my answer: E layer 2 mobility is based on VLANs, no tunnel needed for it between the controllers
6.  Which of the following actions cannot be done in the offline Visual
RF plan?
A. Create a BOM
B. Exporting a plan to the controller
C. Tracking APs and client devices
D. Replicating floor plans
my answer: certainly C, B is annoyingly written, you can make an export and then import it on the controller, but you cant directly export to a controller, so assuming 1 answer that would be C
8.  (group8) #show ap active
Active AP Table
Name    Group      IP Address      11g Clients   11g Ch/EIRP/MaxEIRP   11a Clients   11a Ch/EIRP/MaxEIRP
AP1      building1    10.1.80.150       0                       AM                                 0             AP:HT:149+/19/19
AP2      building1    10.1.80.151       0                       AM                                 0             AM
A user has called technical support because they cannot see any of
their APs in building one. You perform the “show” command as
illustrated above.
What can you conclude about these two APs from this output?
A.  The GRE for the APs terminate on two different controllers:
10.1.80.150 and 10.1.80.151
B.  The system will not function because there is no building1
group defined
C.  The building1 APs are configured to not accept any user
connections
D.  The user needs to configure his client to use the b/g band
E.  The user needs to configure his client to use the a band
my answer: E, that appears to be the only band were one of the APs is an AP and not an Air Monitor, which it is on both bands on AP2 and on the b/g band on AP1. i do find the question also a bit annoyingly written, cannot "see" their APs, that could mean it was placed above the ceiling for example :smileyvery-happy:
10.  A Remote AP provisioned with an SSID in the operational mode
“always” has which one of the following characteristics?
A.  The RAP must obtain its configuration from the controller each
time it boots
B.  The operational mode applies to tunnel and split-tunnel
forwarding SSID
C.  The operational mode applies to a Bridge forwarding SSID
D.  The RAP does not support this mode
E.  The SSID only appears if the AP does not see the controller
my answer: C, it is on always, no matter the status of the controller, which is only useful for
bridged mode
12.  Which of the following charts are available for selection in the
Spectrum Dashboard for an AP-125?
A.  FFT Duty Cycle
B.  Channel Quality
C.  Active Devices by Channel
D.  Number of Spectrum Monitors
my answer: the lack of working with this feature is showing, i know it cant do A and can do B from the AP matrix, D doesnt appear to be something linked to an AP, C i can imagine is true also, so ending up with B and C.
MVP
Re: 6.1 study guide - even questions
Where is this study guide located? URL?
Sean Rynearson
MVP
Ooh that is cool. I already have ACMP but these new. SG look awesome.
Sean Rynearson
For #2. You are correct. It is based on the number of users.
Pulled from the Aruba Mobility Controllers version 8 VRD
CSS licensing is based on three components: total user count, feature bundles, and contract
length (1 or 3 years).
A.  Basic IP
B.  GRE
C.  IPinIP
D.  Mobile IP
RF plan?
A. Create a BOM
Active AP Table
illustrated above.
group defined
connections
time it boots
forwarding SSID
bridged mode
A.  FFT Duty Cycle
B.  Channel Quality
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
