Training, Certification & Career
Frequent Contributor I
ANT-3x3-D608 with AP-274
Hi Every one,
I face a problem regarding ANT-3x3-D608. I want to use this Antenna with AP-274. As we know the AP-274 have 6 RF ports, 3 for 2.4 Ghz and 3 for 5Ghz. Now i want client coverage from both radios (2.4 and 5), and the antenna D608 is capabile to work on both radios. So what i will do now?
As per my understanding, if i connect D608 on 2.4Ghz radios it will receive/transmit in 2.4Ghz range and if i connect the same antenna on 5Ghz radio it will receive/transmit in the 5Ghz range.
Please needs advice from you people to suggest me to install the antennas with proper ports and make on-air my network.
Re: ANT-3x3-D608 with AP-274
You'll be needing 1 x ANT-3x3-D608 per radio so 2 x per AP-275.
Regarding how to plug the antenna in see this post: http://community.arubanetworks.com/t5/Wireless-Access/Aruba-Outdoor-AP-274-ANT-3x3-D608-Antennas/td-p/188756
Cheers
James
