Training, Certification & Career
Are there simulators to help learn WLAN Controller configuring?
I been wondering if there is some type of software that I can use or buy so I can learn basic Aruba WLAN Controller configurations.
I have studied some Cisco router\switches programming with Packet Tracer and I was wondering if there is something similar but for configuring WLAN Controllers without having to buy the physical equipment?
Frequent Contributor II
Re: Are there simulators to help learn WLAN Controller configuring?
Hi!
Unfortunately, there are no tools like the Packet Tracer available for Aruba equipment.
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
