Training, Certification & Career
Documents with typical failures in Aruba Controller 7240
Hi All
Please I need a document with the typical failures in Aruba Controller 7240. Where can find?
Thanks for your help
David
Re: Documents with typical failures in Aruba Controller 7240
Do you mean MTBF?
Hi Colin
The document that I need is a summary with the failures that more occurs in controller. Or repository with any poblems of the controller.
David
