Training, Certification & Career
Airheads Gadget Princess
EMEA Airheads On Demand Tech Webinars
The Airheads Technical Webinars are regularly scheduled live online technical discussions conducted with channel/customer SE’s to help them further their understanding of Aruba technology and solutions. Topics to be discussed will vary based on interest at the time or relevant Aruba technological topics or announcements.
ACCESS OUR ON DEMAND WEBINARS
Virtual Switching Framework – ArubaOS Switch
Webinar Recording & Slides
During this webinar, we will discuss how Virtual Switching Framework (VSF) allows supported switches connected to each other through Ethernet connections (copper or fibre) to behave like a single chassis switch.
CHECK OUT THE WEBINAR RECORDING
 Aruba Central with Instant AP
During this webinar, we will cover the Central platform which provides a standard Web-based interface that allows you to configure and monitor multiple Aruba Instant networks / Switches from anywhere with a connection to the Internet.
AirGroup profile changes across 8.1 & 8.2 – ArubaOS 8.x
In this presentation, we will discuss how AirGroup configurations have changed to support hierarchical configuration in release 8.2. AirGroup configs will now be profile based and can be applied at any node.
Getting Started with the ClearPass REST API
In this presentation, we will explore the REST API as the ClearPass API integrations and further developments are more focused to REST API than the other existing API services like xml-rpc, SOAP, etc.
AP DISCOVERY & DEPLOYMENT POLICY - ARUBAOS 8.X
During this webinar, we will discuss how starting from ArubaOS 8.2.0.0, selected APs can run in both controller-based mode and controller-less mode and the implications tied to that.
Layer-3 Redundancy for Mobility Master - ArubaOS 8.x
In this webinar, we will discuss the L3 Redundancy Requirement which primarily comes from customers who want to handle the complete Data Center Failure during natural disasters or other catastrophic events.
Manage Devices at Branch Office (BOC)
In this webinar, we will discuss how branch controllers work and run through different deployments examples in 6.x and 8.x.
What does AirMatch do differently?
The existing channel and power assignment functions in ARM support channel scanning, channel assignment and power adjustments, locally. Decisions are made locally at the AP without looking at the entire network. Thanks to the dynamic machine learning techniques, AirMatch centralises this function in the Mobility Master while dynamically learning the network and adapting the RF planning for the entire network. Check out What does AirMatch do differently?
Configuring different APIs in Aruba 8.x
During this on-demand webinar, we will run through different API types and cases: configuration APIs (REST API), context APIs (NBAPIs), SDN APIs and explain how to make API calls via CLI.
Aruba Remote Access Point (RAP) Troubleshooting
During this on-demand webinar, we will be debugging Aruba RAP commands, run through troubleshooting and logs and tackle RAP clusters.
Multi-zone AP and Centralized image upgrade
During this on-demand webinar, we will cover basic requirements and supported topologies for Multizone AP, how to bring up APs in multi-version and how the AP's image upgrade differs in 8.x.
Bringing up an Aruba MM, MD & APs
During this on-demand webinar, we will cover how to bring up an Aruba MM, MD and APs and also go through some basic troubleshooting commands.
How Licensing Works in ArubaOS 8.x
During this on-demand webinar, we will cover an overview of ArubaOS 8.x Licensing from Supported/ Unsupported Topology to Server Failover behaviour and license generation and transfer.
ARUBA 8.X ARCHITECTURE OVERVIEW & UI NAVIGATION
During this on-demand webinar, we will run through the 8.x Architecture configuration model and share some UI navigation features such as managed controllers and spectrum monitoring, geolocation and maps.
ARUBA INSTANT AP- VPN TROUBLESHOOTING
This webinar will cover the IAP-VPN architecture which includes the following two components: IAPs at branch sites and controller at the datacenter.
ArubaOS - Cluster Manager
This webinar covers ArubaOS' Cluster Manager, a combination of multiple managed devices working together to provide high availability to all the clients and ensure service continuity when a failover occurs.
Aruba Clarity. Because a Wi-Fi Problem's Often Not a "Wi-Fi" Problem
Today, most mobile connectivity issues are quickly attributed to “bad Wi-Fi”. Very often it may not be a wireless or RF related issue at all. With Aruba Clarity, IT organisations now have visibility into non-RF metrics not only giving them end-to-end visibility into a wireless user experience, but also the ability to foresee connectivity issues before users are even impacted.
ClearPass Extensions and how they can help
Webinar Recording+ Slides
ClearPass Extensions allow ClearPass to integrate with multiple enterprise services to cover dynamic real-time requirements like automatic guest registration and MDM integration. Microsoft Intune, McAfee ePolicy Orchestrator are some examples of integrations achieved using ClearPass Extensions.
 ArubaOS - Rogue AP troubleshooting
This webinar will run through some Rogue AP troubleshooting scenarios and best practices. The agenda covers Rogue AP Detection, classification techniques and containment, wired containment and wireless containment without Tarpit.
ArubaOS - High availability with AP Fast Failover
Webinar Recording + Slides
This webinar will cover ArubaOS’ AP Fast Failover feature, extended controller capacities, how to configure High Availability and several deployment models.
 ClearPass guest with MAC- caching using Time Source
Watch this webinar and learn more on authenticating guest users with ClearPass with Time Source authentication source and MAC- caching
ClearPass - Dot1x: Purpose of domain joining
Watch this webinar and learn more how to implement 802.1x authentication with ClearPass and how to authenticate users of an active directory domain.
Aruba OS – Aruba controller features used to optimize performance
A collection of several vital configuration tips and tricks which are widely implemented across mid-size to large enterprise WLAN. Primary focus would be on Security as well as Performance characteristics of Aruba WLAN networks.
