Training, Certification & Career
Instructor-led technical courses in the states
I can´t find formal instructor-led technical courses AICU & ATS in the states with locations, the only courses i can find are "virtual courses". Do you know how can i obtain a schedule with locations in the states if any?. Thanks in advance.
Moderator
Re: Instructor-led technical courses in the states
The Aruba website has all of the locations listed there as you saw.  ATS and AirWave classes are almost always delivered as virtual now, with only occasional in person offerings.  That is why you are not seeing listings for other than VILT.
Kevin
