Training, Certification & Career
Need help?
I took the ACMA about 2 years ago? I was wondering when does it expire
Frequent Contributor II
Re: Need help?
Since ACMP does not have ACMA as a prerequisite, it will not matter is your ACMA if still active or not. Whenever you are ready, you can take ACMP :)
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
Re: Need help?
As ACMA may count for your partner status, check out this post on Airheads about how Aruba moved from a fixed validity to a version expiration model:
"The certifications don't have a fixed 3-year expiration anymore. That said, they do expire eventually after newer certifications are released. Therefore, I'd recommend keeping your certification updated as new versions are released."
You can check at this site for Expired and Inactive Exams. There you can see that all ACMA 6.x certifications are inactive. If you need your certifications as part of your partner status, your Aruba channel SE should be able to help you out with more information.
