Training, Certification & Career
Please help me solve the problem !!!
Hi guys
My ACMX is about to expire and I need to re-cert, but I'm not able find out how this is done. I've read some old posts saying it's a proctored written exam, so I'm guessing it might be the 6.4 written exam. But - that exam is pre-req for new ACMX testers before doing the lab. Nothing in regards of re-cert :(
So - anyone know and can link me to the right information?
Thanks!
Re: Please help me solve the problem !!!
The same exam HP6-A40 is both entry pre-requisite for new ACMX, as the renewal exam.
Check here under the Step 5, Prerequisite Path 2.
I was in the same situation a few weeks ago. I'm now re-certified.
This is what you need to take: https://certification-learning.hpe.com/tr/datacard/Exam/HPE6-A40
Good luck!
Cheers
James
