Training, Certification & Career
Occasional Contributor I
Regarding ACMA material
Hello All,
I am pretty much in interested in learning wireless. Where should i start for basics ? ACMA is the correct stage where can i start with or do i need to go for CWNA ? And also where can i find ACMA study guide / material
Super Contributor II
Re: Regarding ACMA material
If you are looking to learn about wireless then the CWNA is great - it will help you understand grass roots concepts that will be useful whichever vendor you work with and will be relevant for years to come. The ACMA is Aruba specific and will only give you a small overview of wireless which you can pick up from a few google searches.
Community Administrator
v-semodu - Check the Becoming Mobility Certified page for some great study tools to prepare for either ACMA or CWNA.
http://community.arubanetworks.com/t5/Training-Certification-Career/Becoming-Mobility-Certified/td-p/130731
Airheads Community - The best place to Connect. Engage. and Learn.
