Training, Certification & Career
Regular Contributor II
Software to help study/test
Is there any software to that of Cisco's PacketTracer to help study/practice without having using a live network? I know there is VisualRF Plan but that is only to help with planning. I mean where you can put different devices (controllers, AP's, RAP's,...) and practice configuring them. Because with PacketTracer you can add a switch then go into the command line and configure it as if you were consoled into it. Is there anything currently that can help with Aruba?
Re: Software to help study/test
If your company is an authorized partner you can ask for vouchers for free trainning
http://www.arubanetworks.com/aruba-partners/channel-partners/program-details/
CHeck out the details in there.
Hope that helps cheers
Carlos
Alternetworks Corp
Moderator
Simulators are something that we would like to have but there's nothing like that at this time.  We're also considering allowing folks to rent equipment through our remote labs but have a lot of work to do on the front end to make that feasible.  No hard plans as of now.
Christopher Leach - CISSP, ACDX, ACMX
Director, Training and Certification
Occasional Contributor I
-- sorry i misunderstood the first post --
i wrote about exam test simulators
Trusted Contributor I
The ability to rent equipment would be great!  I recently went through the ClearPass Bootcamp and all the labs were remote.  There were a few hiccups, but it all worked pretty good.  I would think the same setup could be used for those wanting to rent equipment.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
MVP
What does the demo kit in that list entail? I'm now wondering if I need to go pester some Aruba folk :P
Koen (ACMX #351 | ACDX #547 | ACCP)
