Training, Certification & Career
Witch first? ACMP or ACCP?
I need to pass these 2 exams in a couple of weeks, months. What do you suggest, which exam should I do first, what is the recommendation?
Thanks!
MVP
Re: Witch first? ACMP or ACCP?
I'd recommend starting with the ACMP (Controller). The ACCP (ClearPass) requires that you have a good understanding of how to integrate ClearPass with Network Access Devices like the Controller, so it helps to have the ACMP first before attempting the ACCP. Hope this helps.
Thanks for your reply!
May I ask how hard to take the ACCP exam without ACMP knowledges? (Just wondering, I need to take all of them.)
