Training, Certification & Career
connectivity issue
Using one of the free application , i can see client getting around -65dB Signal strength .
if in case the noise level is very high for example -90 dB somethinng like that  , adding another ap in that area will be good or is just fine .
How can i check the noise level and SNR in aruba.
Re: connectivity issue
To check the signal level of the client, type "show ap association client-mac <mac address of client".
To check the noise, type "show ap debug radio-stats ap-name <name of ap> radio 0 | 1 advanced | include Noise"
-90 is not considered high.
Thank you for the reply .
if the signal strength is -70 dBm and noise is -85dBm
How do we calcualte SNR
Thanks again
SNR = S/N
SNR[dB] = S[dBm] - N[dBm]
-70dBm - -85dBm = 15dB
