Training, Certification & Career
what should be the reason for not broadcasting ssid
 i am beginer to aruba ... even after all ssid config is done master controller is not showing ssid in gui and same in cli page....
regards,
mallikarjun
Re: what should be the reason for not broadcasting ssid
Hi Mallikarjun,
Please share the configuration so that we check the reason for the same.
Just on a side note, do you have AP licenses installed on the controller ?
