Unlisted 1
Re: Convert AP-325 to IAP-325 (almost done, help needed)
Well, we would be very lucky if they exchange them. The fact is sales treat AP and IAP as different models. They wouldn't even know they are interchangable.
If Aruba doesn't allow 'field' conversion, will a TAC case help me out?
Took me a few days to finally resolve this myself. Some one wrote the code at Aruba should really remove the annoying prefix check.
You finally resolved ? What did you do ?   Please help me, thanks .
Likewise I'd be very keen to understand the process. I have one 325 AP I need to get to an IAP to join with another controllerless customer environment.
Ruste, this is not supported. Please reach out to your Aruba partner or account team to see if you can swap the hardware.
Tim Cappalli | Aruba Security TME
Sounds like a great DIY home solution for some old AP's. Very interested in the procedures.
Would love to know how to convert from AP to IAP like you did.
