[VIDEO] How ARM works & how to manually change Power & Channel for IAP
This Video explains the background of how ARM selects the Power & Channel for assigning to a radio. The same information can be used to manully change the power & channel of the APs. This video explains how to interpret ARM information and how to manually change the power & channel. The video is created in code
Version history
Revision #:
2 of 2
Last update:
‎03-07-2014 08:27 AM
Updated by:
Labels (1)
