Voice and Video
VoIP with IPO500 and Avaya 3645 wireless telephone
Has anyone installed a 3200 controller with AP-105, and Avaya 3645 wireless telephone sets registered in an IPO500 pbx?
I'm having problems with some calls that have no audio. :(
Occasional Contributor I
Re: VoIP with IPO500 and Avaya 3645 wireless telephone
Hi Helton,
I asked a colleague and he says that you have to disable "direct media path" in the extension, to force the calls to be routed by the IPOffice.
I had the same problem with Avaya Communication manager, and we did the same (i remember in CM this is called IP-IP or something similar) and it worked. I think the problem is that the phones doesn't negotiate the codec correctly
Let us know if this works
When I removed the parameter that you indicated, the wireless telephones stopped communicating with each other, so I think the problem was not that.
I was using version 6.1.2.2, so I made a downgrade to 5.0.4.2, and apparently the problems were solved.
I will do more tests during this week to check if the system has stabilized.
Thank you for your attention.
Helton
