Wired Intelligent Edge
2-member VSF stack 40 Gbps LACP
  • 1.  2-member VSF stack 40 Gbps LACP
    Posted Sep 19, 2018 07:26 PM
     As per screenshoot attached, I would like to setup LACP (at 40 Gbps) using these DACs. I have configured a single lacp with 4 interfaces on ArubaOS (2930F) side and a single Bridge Aggregation with 4 interfaces on Comware side (5940).
    I've got a BridgeAggregation 1 on IRF Stack - the four ports (5940 2slot);
    Aruba = trunk 10 1/49-1/50 2/49 2/50 lacp
    For now I could only get to work two links (1/49 and 1/50) and the configuration seems correct.
    Is there anything that I am missing here?
    Info#1: There DACs are HPE(Comware) 5 m. I can see some CRC erros.crc error.jpeg
  • 2.  RE: 2-member VSF stack 40 Gbps LACP
    MVP GURU
    Posted Sep 19, 2018 08:48 PM
    Can you provide SKUs of all used DAC Cables?
    Are they 1 meter long?
    Can you share (sanitized) running configuration of IRF and VSF?
    Also outputs of display link-aggregation verbose and show lacp CLI commands would be of help.
  • 3.  RE: 2-member VSF stack 40 Gbps LACP
    Posted Sep 19, 2018 08:54 PM
    They are 5 meters long. Is that a issue?
    JG081C HPE FlexNetwork X240 10G SFP+ to SFP+ 5m Direct Attach Copper Cable
    I'm going to run all the commands and post here ASAP.
  • 4.  RE: 2-member VSF stack 40 Gbps LACP
    MVP GURU
    Posted Sep 19, 2018 09:10 PM
    No, not in your specific case (https://support.hpe.com/hpsc/doc/public/display?sp4ts.oid=null&docLocale=en_US&docId=emr_na-a00056174en_us).
    It looks like that JG081C isn't among 1, 3 and 7 meters long DAC SKUs supported by various Aruba Switch series, Aruba 2930F included.
  • 5.  RE: 2-member VSF stack 40 Gbps LACP
    Posted Sep 21, 2018 01:56 PM
    The LACP is working right now. Not sure exactly why, but the customer rebooted the swithes, but the second VSF link is out. Weird.
    First try:
    Aruba01(config)# vsf member 1 link 1 1/51-1/52
    All configuration on this port has been removed and port is placed in VSF mode.
    Aruba01(config)# show run interface 1/52
    Running configuration:
    interface 1/52
       untagged vlan 1
       exit
    Second try:
    Aruba01(config)# vsf member 1 link 1 1/52
    interface 1/52
       untagged vlan 1
       exit
    Aruba01(config)# show vsf link
     VSF Member 1
                      Link     Peer   Peer
     Link Link-Name   State    Member Link
     1    I-Link1_1   Up       2      1
     2    I-Link1_2   Down     0      0
     VSF Member 2
                      Link     Peer   Peer
     1    I-Link2_1   Up       1      1
     2    I-Link2_2   Down     0      0
    VSF CONFIG
       enable domain 1
       member 1
          type "JL254A" mac-address 98f2b3-bcb780
          priority 128
          link 1 1/51-1/52
          link 1 name "I-Link1_1"
          link 2 name "I-Link1_2"
          exit
       member 2
          type "JL254A" mac-address 98f2b3-bc4840
          priority 128
          link 1 2/51-2/52
          link 1 name "I-Link2_1"
          link 2 name "I-Link2_2"
          exit
       port-speed 10g
       exit
    Also, I've seem some CRCs errors (LACP port that use the DAC Cable 5 meters).
  • 6.  RE: 2-member VSF stack 40 Gbps LACP
    Posted Sep 21, 2018 03:29 PM
    Greetings!
    VSF link 2 shows Down on each member because there are no ports assigned to link 2 on either chassis — both physical VSF ports on both members are assigned to link 1.
  • 7.  RE: 2-member VSF stack 40 Gbps LACP
    Posted Sep 21, 2018 03:34 PM
    Thanks for the reply.
    Shoud I create the link 2? I've just got two dacs for VSF. Whats the best design?
    vsf
       enable domain 1
       member 1
          priority 128
          link 1 1/51
          link 2 1/52
          exit
       member 2
          priority 128
          link 1 2/51
          link 2 2/52
          exit
       port-speed 10g
       exit
     EDIT: I understand that the LINK 2 is for the 3º and 4º switches.
  • 8.  RE: 2-member VSF stack 40 Gbps LACP
    Posted Sep 21, 2018 06:04 PM
    That's correct. A second VSF link could be used for redundancy if you had a second 40G module (it has to be the same speed as the first VSF link), but for a two-switch stack, as long as one VSF link is up the fabric will operate normally.
