Wired Intelligent Edge
2920 stack - SFP slots not working
  • 1.  2920 stack - SFP slots not working
    Posted Jul 16, 2018 11:55 AM
    I have 4x HP/Aruba 2920s configured in a stack using the dedicated stack hardware and cabling. All seems to be working well except for one issue:
    On the first unit which is acting as the "commander", the 4x dual personality ports work for both copper and gbic. On the remaining 3x units in the stack, the gbic slots do not work.
    Inserting a working gbic module into the slot shows no information in the event log - no indication of insertion, failed module, or any entry at all.
    Any idea why the gbic slots aren't working on these other units?  (Slots worked before units were placed in stack.)
    Thanks in advance.
  • 2.  RE: 2920 stack - SFP slots not working
    MVP GURU
    Posted Jul 17, 2018 08:49 AM
    Which software versions the stack is actually running on?
    Can you paste (sanitized) output of show tech transceivers command?
  • 3.  RE: 2920 stack - SFP slots not working
    Posted Jul 17, 2018 09:31 AM
    Stack currently running
    WB.16.05.0007.
    Transceiver Technical Information:
    Port # | Type      | Prod #     | Serial #         | Part #
    1/45   | 1000SX    |     J4858D | X     | 1990-4415
    1/46   | 1000SX    |     J4858B | X
    1/47   | 1000SX    |     J4858C | X      | 1990-3657
    1/A1   | SFP+LR    |     J9151A | X     | 1990-3883
    Xed out the serial numbers.  I don't currently have any gbics installed on the other switches at this moment.  When I do insert a gbic in one of the other units, the LED on the slot doesn't light up (neither green flash when valid gbic inserted or red/orange flashing when faulty / unsupported gbic inserted).
    Thanks in advance.
  • 4.  RE: 2920 stack - SFP slots not working
    Posted Jul 18, 2018 01:38 PM
    I have setup this topology in lab and it seems to work for me.  I have (4) Aruba 2920 Switches in stack running ArubaOS-Version WB.16.05.0007.  I have inserted the supported 1Gb SFPs to Member 3 and 4, and as you can see below in the 'show interface brief' command output that both ports (3/21 and 4/21).
    HP-Stack-2920# show interfaces brief
    Status and Counters - Port Status
    Port  Type     Enabled Status Mode
    3/21  1000SX   Yes     Up     1000FDx
    4/21  1000SX   Yes     Up     1000FDx
    In addition, the following 'show tech transceivers' command output also shows that both ports (3/21 and 4/21) of Member 3 and 4 respectively are supported in the stacking ring.
    HP-Stack-2920# show tech transceivers
    Cmd Info : show tech transceivers
    transceivers
     3/21   | 1000SX | J4858C | CN249DN0BU | 1990-3662
     4/21   | 1000SX | J4858D | CN7BKC5DZB | 1990-4415
    Thank You,
