2930F Over Temperature
I was wondering about the temperature sensor in an Aruba JL258A 2930F-8G-PoE+-2SFP+ Switch. I got log messages from a switch in the field being in too warm.
W 08/03/18 13:44:37 00553 chassis: Over Temperature: Slot 1
W 08/03/18 13:44:47 00553 chassis: Over Temperature: Slot 1
W 08/03/18 13:44:57 00553 chassis: Over Temperature: Slot 1
W 08/03/18 13:45:17 00553 chassis: Over Temperature: Slot 1
W 08/03/18 13:45:27 00553 chassis: Over Temperature: Slot 1
What is the Over Temperature value? I'm used to HP 5400's / 5400R-zl2's only where it is either 40 degrees Celcius or 57 degrees Celcius. Can I read out the sensor like on an 5400R-zl2 switch to see the temperature? The command "show system temperature" doesn't seem to excist... (At least not on WC.16.02.00020 which is our current prefered version.)
