2930F - SNMPv3 Traps sent to target address
Hi I am a SNMP noob and finally was able to do and snmpwalk and receive SNMPv3 traps.
However I am only receiving a very limited amount of notifications. See traps list below.
Is there a way to send more traps, for example, I was expecting to receive a trap when I disabled a port, but I'm not.
Any  ideas? Thanks!
# show snmp-server
 SNMP Communities
  Community Name                   MIB View Write Access
  public                           Manager  Unrestricted
 Trap Receivers
  Link-Change Traps Enabled on Ports [All] : All
  Traps Category                          Current Status
  _____________________________________   __________________
  SNMP Authentication                   : Extended
  Password change                       : Enabled
  Login failures                        : Enabled
  Port-Security                         : Enabled
  Authorization Server Contact          : Enabled
  DHCP-Snooping                         : Enabled
  DHCPv6-Snooping Out of Resource       : Enabled
  DHCPv6-Snooping Errant Replies        : Enabled
  Dynamic ARP Protection                : Enabled
  Dynamic IP Lockdown                   : Enabled
  Dynamic IPv6 Lockdown Out of Resource : Enabled
  Dynamic IPv6 Lockdown Violations      : Enabled
  Startup Config change                 : Disabled
  Running Config Change                 : Disabled
  MAC address table changes             : Disabled
  MAC Address Count                     : Disabled
  DHCP-Server                           : Enabled
  NTP-Client                            : Disabled
  MACsec Failures                       : Enabled
  ND Snooping Out of Resources Traps    : Enabled
  VSF                                   : Disabled
Re: 2930F - SNMPv3 Traps sent to target address
Here is a link to the Traps and MIBs supported on the 2930F and the bit builds of when supported.  Please review and let us know if you need additional information.
https://support.hpe.com/hpsc/doc/public/display?docId=a00038734en_us
ROB HAVILAND
DIRECTOR TME, ARUBA WIRED INTELLIGENT EDGE
M: 414.841.3605 | rob.a.haviland@hpe.com
8000 FOOTHILLS BLVD | ROSEVILLE, CA 95747 USA
