8320 Switch: Forwarding Table Modes
The 8320 Switch has two operation modes. The purpose is to provide the best match in terms of table sizes, depending on the role of the switch.
For example, if the 8320 is acting as an L2 Aggregator (deployed in the aggregation layer with L2 access) it will need large ARP/MAC tables, while when deployed as an L3 Aggregator or Core, it will need larger routing tables and very small ARP/MAC tables.
The mode that works best in the first case is called Mobile First Mode  because it is the most common situation when the 8320 is aggregating L2 access switches and Aruba Mobility controllers.
The mode that fits the second case is called simply Routed Mode and it is the factory default mode of the switch.
Some numbers:
Mode name
Mobile-First
Routed (default)
Forwarding Table Mode Number (CLI)
3
4
L2 entries
98,304
32768
Host entries
120,000
14,000
Route entries
16,384
131,064
The commands to change and display current the forwarding table mode are:
  • Change to Mobile First Modeplatform forwarding-table-mode 3
  • Return to Router Mode: platform forwarding-table-mode 4
 Notes:
  • these commands run in user mode (outside the configure context)
  • the system will reboot to operate in a different mode
Example
8320-01# show platform forwarding-table-mode
Mode    L2 Entries    Host Entries   Route Entries
   4         32768           14000          131064
8320-01# platform forwarding-table-mode 3
This command requires a reboot to take effect.
Do you want to save the current configuration (y/n)? y
<< reboot >>
8320-01 login: admin
Password:
   3         98304          120000           16384
RUBEN IGLESIAS
Global Consulting TME
Aruba Wired Intelligent Edge
Ruben Iglesias
Frequent Contributor II
Re: 8320 Switch: Forwarding Table Modes
Really interesting and, AFAIK, pretty much undocumented explicitly (at least I'm not able to find any reference on the published ArubaOS-CX Command Line Reference Guide for 10.01): the only reference of "platform modes" on Aruba 8320 platform seems that can be found into the ArubaOS-CX 10.01 Virtual Switching eXtension (VSX) Guide recently published...indeed this statement: "Modes for 8320 series switches: All switches must be either in mode 3 or in mode 4." can be found on that guide...but no info on what those modes mean and how/why to correctly manage them.
Given your precious info about that what is going to be the impact on a Aruba 8320 VSX already running in Platform Mode 4 in case the deployment scenario suggests to switch to Mode 3 instead of staying at default? it will be a matter of just rebooting each node and be prepared for related reboot downtime and nothing more or could be there other issues once both nodes came up again to reform the VSX?
Thanks, Davide.
Occasional Contributor I
Hi Davide,
Updated documentation covering this feature is coming  soon.
You are correct in that aside from changing the mode on both VSX devices and performing a reboot there should be no other issues to address.
One of the lab tests the TME team performed was to take a pair of 10.0 switches, upgrade to 10.1 and then change the forwarding mode to 'mobile first' (mode 3).  In performing this test, we didn't observe any issues with VSX forwarding post-upgrade.
I'll test that tomorrow morning...but, as I wrote, our VSX is not connected to any downstream or upstream peer with any VSX-LAGs so, for me, actually...having "no issues" means that, after the platform mode change and required reboot, I will find the configuration I left (saved) and the VSX reforms flawlessly. Nothing more and nothing less...currently.
I'll report back tomorrow.
No issues so far, VSX up and running again.
Now:
Aruba-8320-1# show platform forwarding-table-mode
Aruba-8320-1# show platform forwarding-table-mode vsx-peer
Good. Thanks.
