Hello Team,
I am trying to configure port security with mac limit and i set the port to learn mode of limited-continuous,address-limit of 1 and action send-disable.
In aruba 5406 version 16.06.0006 they have add also disable-timer
'Configure number of seconds after which disabled ports are automatically re-enabled' but i can not find the same command at aruba 2540 version 16.06.0006.
Is there any other way to auto enable the port after some time?
Thanks in advance.
#2540
