Hi all,
Been having some issues trying to get the switch I'm setting up to sync to the windows NTP server. Have copied the input I have used below:
Essella-First-1-Aruba2920(config)# timesync ntp
Essella-First-1-Aruba2920(config)# ntp unicast
Essella-First-1-Aruba2920(config)# ntp server 10.33.116.20
Essella-First-1-Aruba2920(config)# ntp server 10.33.116.20 iburst
Essella-First-1-Aruba2920(config)# ntp enable
Essella-First-1-Aruba2920(config)# show time
Wed Aug 15 10:14:20 2018 (manually set the time previously)
Essella-First-1-Aruba2920(config)# show ntp status
NTP Status Information
NTP Status : Enabled NTP Mode : Unicast
Synchronization Status : Not Synced Peer Dispersion : 0.00000 sec
Stratum Number : 16 Leap Direction : 0
Reference Assoc ID : 0 Clock Offset : 0.00000 sec
Reference ID : 0.0.0.0 Root Delay : 0.00000 sec
Precision : 2**-18 Root Dispersion : 0.93408 sec
NTP Up Time : 0d 17h 17m Time Resolution : 2789 nsec
Drift : 0.00000 sec/sec
System Time : Wed Aug 15 10:14:41 2018
Reference Time : Mon Jan 1 00:00:00 1990
Essella-First-1-Aruba2920# show conf
Startup configuration: 10
; J9728A Configuration Editor; Created on release #WB.16.02.0012
; Ver #0e:01.b0.ee.34.5f.3c.29.eb.9f.fc.f3.ff.37.ef:73
hostname "Essella-First-1-Aruba2920"
module 1 type j9728a
console idle-timeout 600
banner motd
MOTD
password minimum-length 8
timesync ntp
sntp broadcast
sntp server priority 1 10.33.116.20 1
ntp unicast
ntp enable
no telnet-server
ip default-gateway 10.33.116.1
ip dns server-address priority 1 10.33.116.20
ip dns server-address priority 2 10.33.116.21
ip timep dhcp
snmp-server community "public" unrestricted
snmp-server location "Essella First (TB3/F)"
oobm
ip address dhcp-bootp
exit
vlan 1
name "DEFAULT_VLAN"
untagged 1-48
ip address 10.33.116.174 255.255.252.0
exit
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
password manager
password operator
Not sure if I have just missed something, was messing around with it for quiet some time yesterday.
Dan
