Aruba 3810m - Reset to defaults?
We are just beginning to use Aruba Network gear. I was testing a switch to learn how to configure them. I left it alone for about a week and have forgotten the login information that it was cofigured with. Is there a process to reset the switch to defaults, or a password recovery process?
Re: Aruba 3810m - Reset to defaults?
This works well
erase all
Richard Litchfield, HPE Aruba
Network Solution Architect
Network Ambassador
Yes that is correct, my main obstacle was getting past the login, since that was forgotten.
Pressing the clear button twice for 5 seconds, cleared the logins. Then I was able to do an Erase All to clear the config.
Thank you for your reply!
