Contributor I
Automatically backup config to scp or tftp when “wr me”
In Cisco, I can automatically backup config using scp or tftp to other location every time I issue “wr me”
How to achieve the same in other brand?
CISCO:
archive
path scp://root:eve@10.0.10.70/$h
write-memory
HP:
Re: Automatically backup config to scp or tftp when “wr me”
Not sure if this is possible. Until now I didn't saw this. there are multiple ways in manually making backup's and upload them via SFTP / FTP in single commands. There is also option to restore these backups without reboot. In order to achieve similar process like your I see a lot of organizations enable the following snmp trap:
snmp-server enable traps startup-config-change
when the management system than receives this trap it automatically makes backup. Maybe this will also work for you.
Regard, Dobias
