GRE tunnel between two switches
Is it possible to create a tunneled node / GRE tunnel directly between two switches? The goal is something like this:
vlan 7 ---- swtich A ---- itermediate routed network (no NAT) ------ Switch B ---- vlan 7 (same broadcast domain as the first.
Re: GRE tunnel between two switches
ArubaOS-Switch does not support GRE tunnels from switch to switch, only between Mobility controller to switch.
Justin
But it looks like VXLAN will achieve my goal similarly?
NOTICE: The information contained in this e-mail, including any
attachments, is confidential, intended only for the named recipient(s), and
may be legally privileged. If you are not the intended recipient, please
delete the e-mail and any attachments, destroy any printouts that you may
have made and notify us immediately by return e-mail.
Yes, it will be possible with VXLAN for this case
ACMP 6.4 / ACMX #107 / ACCP 6.5
Frequent Contributor II
But will that required jumbo MTU throughout the path.
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
