Occasional Contributor I
HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
I have a particular tipology, the 2 aruba will receive each 1 uplink from the "MAIN" provider and 1 uplink for the "backup line" from another provider.
i configure VSF for the redudancy but now the 2 switch are configured like 1 single switch and when i connect the 2 uplinks, i create a loop :s so i search a little bit and i founded a topic who spoke about MADVLAN but i tryed it and i didn't have more result.
Have you an idea to do that?
Here are the running config.
Running configuration:
; hpStack_WC Configuration Editor; Created on release #WC.16.06.0006
; Ver #13:4f.f8.1c.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:05
hostname "MSW001"
vsf
   enable domain 1
   member 1
      type "JL258A" mac-address 94f128-8cf060
      priority 160
      link 1 1/7-1/8
      link 1 name "I-Link1_1"
      link 2 name "I-Link1_2"
      exit
   member 2
      type "JL258A" mac-address 94f128-8cf010
      priority 150
      link 1 2/7-2/8
      link 1 name "I-Link2_1"
      link 2 name "I-Link2_2"
      exit
   port-speed 1g
   exit
ip default-gateway 192.168.8.1
interface 1/1
   no power-over-ethernet
   exit
interface 1/2
   exit
interface 1/3
   exit
interface 1/4
   exit
interface 1/5
   exit
interface 1/6
   exit
interface 1/7
   exit
interface 1/8
   exit
interface 2/1
   exit
interface 2/2
   exit
interface 2/3
   exit
interface 2/4
   exit
interface 2/6
   exit
interface 2/7
   exit
interface 2/8
   exit
snmp-server community "aruba"
vlan 1
   name "Stack_MSW001"
   untagged 1/1-1/6,1/9-1/10,2/1-2/6,2/9-2/10
   ip address 192.168.8.5 255.255.255.0
   exit
Regular Contributor II
Re: HELP - (NEWER ARUBA USER) - DOING FAILOVER with 2 switchs ARUBA 2930f
Hi
More info on the link below. Setup a separate vlan between the two units not over link to the isp
http://community.arubanetworks.com/t5/Campus-Switching-and-Routing/VLAN-MAD-in-2930F/m-p/300856
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Ok thanks, but i can't use vlan. the provider the main line and the backup line must be on the same lan, they ney need to see each other for the failover.
the switch receive the main line (uplink), backup line (uplink), 2 connections firewall.
and all of them need to see each other.
thanks for your answer
You don’t need mad vlan on all links. Just use a separate one
Cheers, Frank
Maybe you can use lacp to the uplinks
Cheers, Frank
Okay, so i have to do?
VLAN 1
untagged 1/3,1/4,1/5,1/6,2/3,2/4,2/5,2/6
Uplink on port 1
SWITCH 1:
trunk 1/1,2/1 trk1 lacp
vlan 11
tagged trk1
trunk 1/2,2/2 trk2 lacp
vlan12
tagged trk2
trk1
mode trunk
allowed vlan 1,11,12
no shut
trk2
mode trunk
allowed vlan1,11,12
no shut
SWITCH2:
same configuration
Hi Eonix,
That looks correct, in your config, if trk1 completely fails across both stack members, trk2 can take over.
Justin
JUSTIN NOONAN
TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
O: +1 916 540 1748   |   justin.noonan@hpe.com
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
GARTNER AGREES: VISIONARY LEADER IN CAMPUS NETWORKING
but i have a question :
From when a trunk link is down for the failover?
Because i will made a trunk with 2 ports. In the trk1 , if 1 of them is down, the 2nd port take all bandwith or the switch, switch with the other trunk trk2?
Hi
When one port in a two port trunk goes down the trunk works on that one port.
Cheers, Frank
The configuration work well. Thanks you very much
