Help! Equivalent commands Cisco/Aruba Switch
Hello everyone!
I need help to configure the switch port of switch aruba. The Cisco Commands are:
interface GigabitEthernet0/6
 switchport trunk native vlan 131
 switchport trunk allowed vlan 131,133,138
 switchport mode trunk
I need to apply it to aruba switch. How would the equivalent be? I'm sorry for my English. I am from Argentina. Thank you very much.
Re: Help! Equivalent commands Cisco/Aruba Switch
Aruba switches have a notion of tagging/untagging vlans to an interface.
You can download a free guide here that shows the equivalent commands
https://hpepress.hpe.com/product/ArubaOS-Switch+Comware+and+Cisco+IOS+CLI+Reference+Guide-PDF-18113
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Indeed please refer to that great guide to get you started migrating the config.
Your snippet will convert into something like:
vlan 131 untagged 0/6
vlan 133 tagged 0/6
vlan 138 tagged 0/6
Thank you for your answers. I will try to configure the Aruba switch. It is to connect an Aruba access point. I will indicate if it works. thanks and sorry for my english.
Thank you! it worked!
