Loop-protect best practice
I have switches where on the uplinks to other switches, loop-protect is enabled, and the other switches work fine (bpdu-filter/protect/admin-edge-port disabled).
On other switches i have loop-protect specifically disabled for uplinks.
What's the recommended best practice?
Also a followup question regarding HP access points connected to HP/Aruba switches:
I know i need to disable port-security on AP ports or i get into trouble with more devices connected to it (than 3 for example). Do i also need to disable bpdu-filter/protect/admin-edge port/loop-protect on these ports?
Re: Loop-protect best practice
Anyone? :)
Hello Pepe,
I can only speak for ourselves but we run the following configuration for all our switches, enabling it on all ports (so both uplink and edge ports) for as long as I can remember:
loop-protect <ALL_PORT_LIST> receiver-action send-disable
loop-protect trap loop-detected
loop-protect transmit-interval 1 disable-timer 300
Kind regards,
Niels Mejan
University of Twente
