Multicast Testing Tool
Test Tools
MCastTester
I have finally found a multicast test tool that actually works. It is simple to use with no installation required, including on older machines (like the discarded laptops that always seems to end up in the lab).
Try MCastTester from http://www.dqnetworks.ie/toolsinfo/mcasttest/
VLC
VLC is often suggested as a test tool to generate and consume multicast content. Unfortunately however, I have always been a bit dubious of VLC because it sometimes doesn't work, and then you spend time troubleshooting VLC-related issues (eg underpowered devices, incompatible media, mismatched versions, etc). Once you have have done the initial setup and testing, and you have a working environment, VLC can provide immediate audio and/or visual feedback as consuming devices connect.
MCastTester Example
Configured as the transmitter:mcast-transmitter.png
Configured as the receiver:mcast-receiver.png
Wireshark capture:mcast-wireshark-traffic.png
Output from a ProCurve/AOSS switch:
bvcore01(config)# show ip igmp vlan 100
 IGMP Service Protocol Info
  Total VLANs with IGMP enabled                : 9
  Current count of multicast groups joined     : 6
  IGMP Filter Unknown Multicast: Disabled
  IGMP Filter Unknown Multicast Status: Disabled
  VLAN ID : 100
  VLAN Name : BV-Main
  IGMP version : 2
  Querier Address [this switch] : 172.20.100.1
  Querier Port :
  Querier UpTime : 86d 9h 49m 36s
  Querier Expiration Time : 0h 2m 5s
  Active Group Addresses Type       Expires         Ports      Reports Queries
  234.5.6.7              Filter     0h 2m 54s       F4         2       0
Richard Litchfield, HPE Aruba
Network Solution Architect
Network Ambassador
Re: Multicast Testing Tool
I recently did a multicast video poc with a partner using vlc and had lots of problem... but when I start doing it by using non Hpe coe laptop... it works like champ..I suspect it’s the problem with coe setting...
I can see where that lack of complete access would cause problems - one of the reasons I have never had a COE machine and always built my own. When I was doing this testing, I had multiple laptops, OS versions, brands, partners builds, etc.
I generally found that once the solution was tested and working OK with the MCastTest tool, then VLC would often work. However, there were a few systems that it just didn't like - mainly older ones that may have had resourcing issues.
Network Ambassador
