Wired Intelligent Edge
PUTTY - ssh column width or column value
  • 1.  PUTTY - ssh column width or column value
    Posted Sep 20, 2018 04:16 PM
    I am sshing using PUTTY client but not able to see full values for the columns. How should increase the width or what to see full values for the columns?
    Here is what I see. How to full values for PortId and PortDesc?
    LLDP Remote Devices Information
    LocalPort | PortId PortDescr SysName
    15 | Gig... Uplink... Sw3
    17 |  Gig... Uplink... Sw2
    23 |  Gig... Gigabi... CoreSw1
    24 |  Gig... Gigabi... CoreSw1
  • 2.  RE: PUTTY - ssh column width or column value
    MVP GURU
    Posted Sep 21, 2018 06:16 AM
    Hi Nick,
    there is no real solution... (for change column width)
    You can use show lldp neighbor neighbor or use API.. ;-)
  • 3.  RE: PUTTY - ssh column width or column value
    Posted Sep 21, 2018 03:23 PM
    Greetings!
    That seems a bit narrower than I'm seeing from my own switch console (via serial or SSH). Have you tried using the command terminal reset? This causes the switch to read the properties of the current terminal window and set the console width and height appropriately. Also, check the PuTTY session configuration (Configuration -> Window) and adjust the Columns and Rows values as appropriate.
