Wired Intelligent Edge
aruba switch - vlans missing in menu
  • 1.  aruba switch - vlans missing in menu
    Posted Jul 18, 2018 05:22 AM
    hello gentleman.
    i colleguejust came by and asked me why there aren't all vlans shown in the menu. i see all vlans set at vlan names, but in the vlan port assignement i am missing some of them. is there a max number for vlans to be shown in the vlan menu?
    CLI is fine
    cheers,
    raffa
  • 2.  RE: aruba switch - vlans missing in menu
    Posted Jul 18, 2018 08:08 PM
    Hi Raffa,
    I believe the menu window that you're looking at, the vlan address table, just shows the current mac-addresses that are on that specific port and VLAN.
    I think the information that  you want to see is under "switch configuration" -> "VLAN Menu" -> "VLAN Port Assignment".
    Hope this helps,
    Justin
    JUSTIN NOONAN
    TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
    O: +1 916 540 1748   |   justin.noonan@hpe.com
    8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
    GARTNER AGREES: VISIONARY LEADER IN CAMPUS NETWORKING
  • 3.  RE: aruba switch - vlans missing in menu
    Posted Jul 19, 2018 06:05 AM
    hello justin
    thats the point - i am in the vlan port assignment menu. but if i go to the right, a few vlans are missing. if i go to vlan names, all the vlans are there.
    that is why i am asking if there is a maximum for vlans to be shown in the port assignment menu.
    hope you can follow.
    regards,
    raffa
  • 4.  RE: aruba switch - vlans missing in menu
    Posted Jul 20, 2018 11:54 AM
    Hi Raffa,
    The menu interface only supports displaying up to 32 VLANs for VLAN port assignment, you'll need to use the CLI to assign ports to more than 32 VLANs.
    This is documented in the Advanced Traffic Management Guide on Page 35.
    https://support.hpe.com/hpsc/doc/public/display?docId=a00050236en_us
    Justin
