ArubaOS-Switch – How to Configure a Management VLAN
MVP
MVP
This feature creates an isolated network for managing the Aruba switches that offer this feature. When a secure management VLAN is enabled, inband CLI, Menu interface, and WebAgent access is restricted to ports configured as members of the VLAN.
In the following example, switches Rack2sw1, Rack2sw2 and Rack2sw3 are configured with VLAN 100 as the management VLAN. The Network Management Station has two interfaces that are able to reach the switched network. After the management VLAN is configured, CLI access from the Cloud fails.
The configuration, verification, and testing associated with the diagram follows:
  • VLAN configuration :
    Rack2sw1# show running-config vlan
    Running configuration:
    vlan 1
       name "DEFAULT_VLAN"
       untagged A1-A24,B1-B24,C1-C24,D1-D24,F1-F24,J1-J4,K1-K4,L1-L4
       ip address 192.168.2.1 255.255.255.0
    vlan 100
       name "VLAN100"
       tagged K1,L1
       ip address 192.168.100.1 255.255.255.0
    Rack2sw2# show running-config vlan
    vlan 1
       name "DEFAULT_VLAN"
       untagged A1-A24,B1-B24,C1-C24,D1-D24,E1-E2,G1-G24,H1-H2,J1-J4,K1-K4,L1-L4
       ip address 192.168.2.2 255.255.255.0
    vlan 100
       name "VLAN100"
       tagged D1,L1
       ip address 192.168.100.2 255.255.255.0
    Rack2sw3# show running-config vlan
    vlan 1
       name "DEFAULT_VLAN"
       untagged A1-A24,B1-B24,C1-C4,D1-D24,F1-F4
       ip address 192.168.2.3 255.255.255.0
    vlan 100
       name "VLAN100"
       tagged B1,C1
       ip address 192.168.100.3 255.255.255.0
  • VLAN verification :
    Rack2sw1# show vlans ports k1,l1 detail
     Status and Counters - VLAN Information - for ports K1
      VLAN ID Name                 | Status     Voice Jumbo Mode
      1       DEFAULT_VLAN         | Port-based No    No    Untagged
      100     VLAN100              | Port-based No    No    Tagged
     Status and Counters - VLAN Information - for ports L1
    Rack2sw2# show vlans ports d1,l1 detail
     Status and Counters - VLAN Information - for ports D1
    Rack2sw3# show vlans ports b1,c1 detail
     Status and Counters - VLAN Information - for ports B1
     Status and Counters - VLAN Information - for ports C1
  • Testing without management VLAN configured :
    Rack2sw1# telnet 192.168.2.2
    Lab 2 Switch 2
    Press any key to continue
    Rack2sw2#
    Rack2sw1# telnet 192.168.2.3
    Lab 2 Switch 3
    Rack2sw3#
    Rack2sw1# telnet 192.168.100.2
    Lab 2 Switch 2
    Rack2sw2#
    Rack2sw1# telnet 192.168.100.3
    Lab 2 Switch 3
    Rack2sw3#
  • Configure management VLAN :
    Rack2sw3(config)# management-vlan 100
    Rack2sw2(config)# management-vlan 100
  • VLAN management verification :
    Rack2sw1# show running-config | include management
    management-vlan 100
    Rack2sw2# show running-config | include management
    management-vlan 100
    Rack2sw3# show running-config | include management
    management-vlan 100
  • Testing with management VLAN configured :
    Telnet closed: Connection closed by host.
    Lab 2 Switch 2
    Rack2sw2#
    Lab 2 Switch 3
    Rack2sw3#
  • Testing IP routing from the network management station :
    C:\>ping 192.168.2.1 -n 1
    Pinging 192.168.2.1 with 32 bytes of data:
    Reply from 192.168.2.1: bytes=32 time<1ms TTL=254
    C:\>ping 192.168.2.2 -n 1
    Pinging 192.168.2.2 with 32 bytes of data:
    Reply from 192.168.2.2: bytes=32 time<1ms TTL=254
    C:\>ping 192.168.2.3 -n 1
    Pinging 192.168.2.3 with 32 bytes of data:
    Reply from 192.168.2.3: bytes=32 time<1ms TTL=254
    C:\>ping 192.168.100.1 -n 1
    Pinging 192.168.100.1 with 32 bytes of data:
    Reply from 192.168.100.1: bytes=32 time<1ms TTL=254
    C:\>ping 192.168.100.2 -n 1
    Pinging 192.168.100.2 with 32 bytes of data:
    Reply from 192.168.100.2: bytes=32 time<1ms TTL=254
    C:\>ping 192.168.100.3 -n 1
    Pinging 192.168.100.3 with 32 bytes of data:
    Reply from 192.168.100.3: bytes=32 time<1ms TTL=254
  • Testing Telnet connectivity :
    C:\>telnet 192.168.100.1
    Lab 2 Switch 1
    Rack2sw1#
    C:\>telnet 192.168.100.2
    Lab 2 Switch 2
    Rack2sw2#
    C:\>telnet 192.168.100.3
    Lab 2 Switch 3
    Rack2sw3#
    C:\>telnet 192.168.2.1
    Server unexpectedly closed network connection
    C:\>telnet 192.168.2.2
  • Management packet counters :
    Rack2sw1# show system  | begin Mgmt
      IP Mgmt  - Pkts Rx : 389,098
                 Pkts Tx : 455,384
    Rack2sw2# show system  | begin Mgmt
      IP Mgmt  - Pkts Rx : 573,759
                 Pkts Tx : 623,562
    Rack2sw3# show system  | begin Mgmt
      IP Mgmt  - Pkts Rx : 312,327
                 Pkts Tx : 368,304
  • Physical interconnect :
    Rack2sw1# show lldp info remote-device
     LLDP Remote Devices Information
      LocalPort | ChassisId                 PortId PortDescr SysName
      A1        | 00 23 47 c0 e8 c0         1      1         Rack2sw5
      K1        | 00 19 bb 16 af 00         49     C1        Rack2sw3
      L1        | 00 18 fe ef a5 00         265    L1        Rack2sw2
    Rack2sw2# show lldp info remote-device
      C1        | XRD6heha                  00 ... HP NC3... DL380G2A47U30
      D1        | 00 19 bb 16 af 00         25     B1        Rack2sw3
      L1        | 00 17 08 cd 05 00         265    L1        Rack2sw1
    Rack2sw3# show lldp info remote-device
      B1        | 00 18 fe ef a5 00         73     D1        Rack2sw2
      C1        | 00 17 08 cd 05 00         241    K1        Rack2sw1
Version history
Revision #:
1 of 1
Last update:
3 weeks ago
Updated by:
