Auto device Config
Question
What is Auto device Config on MAS and how to configure it?
Answer
This article is applicable from 7.4.0 and above
Auto Device detection and Configuration dynamically configure ports based on the type of device detected on the port.
When the MAS detects a new device on a port, it will apply appropriate configuration based on the predefined configuration for that device type.
Link Layer Discovery Protocol (LLDP) is used to detect devices.
Enable  Auto device Config
(ArubaS1500-24P) (config) #device-group ap
(ArubaS1500-24P) (device-group access-point) #enable
Configure device-group based config
show device-group-config <device-type>
(ArubaS1500-24P) #show device-group-config ap
device-group access-point (N/A)
Parameter                        Value
Enable Device Config             false
Enable Auto LACP                 true
Interface MSTP Profile           mstpEdge
Interface GVRP Profile           N/A
Interface PVST Profile           PVSTEDGE
Interface LLDP Profile           device-group-default
Interface PoE Profile            device-group-default
Interface Ethernet Link Profile  default
Interface QoS Profile            N/A
Interface Policer Profile        N/A
Interface AAA Profile            mac-ics-dot1x
Interfaces To Shutdown           N/A
Interface MTU                    1514
Interface Ingress ACL            N/A
Interface Egress ACL             N/A
Interface Session ACL            N/A
Interface QoS Trust Mode         auto
Interface Switching Profile      access_vlan_30
Interface Security Profile       N/A
Interface Trusted Mode           Untrusted
The way device-group works is that, once an aruba ap is detected on an interface via lldp; configuration of the interface will be overwritten by what is specified in deivce-group, so lets say initially the interface-config was switch-profile xyz and pvst-profile abc however in device-group there is switching-profile u and pvst-profile w till a device is connected to the interface which is not an aruba ap, the interface config is valid on that once ap is detected, the interface config gets overwritten
Note: Currently supported only for Aruba AP/IAP that can send Aruba’s Proprietary LLDP TLV
Version history
Revision #:
2 of 2
Last update:
‎11-08-2014 11:56 PM
Labels (1)
Contributors
