Check ARP entry on the AP
MVP
MVP
Q:
How to check if the AP is learning the ARP entry of the client?
A:
The following commands would help when troubleshooting client connectivity issues , were clients ARP entry can be checked from the AP level.
(10.1.1.58) (config) #show ap monitor are p-cache ap-name ac:a3:1e:c3:63:78
br0:10.1.1.2
ARP Cache Table
mac                ip        vlanid  age
f0:dc:e2:67:de:6d  10.1.1.7  0       3m:2s
00:16:ea:f0:f0:3e  10.1.1.8  0       26s          <-------shows the arp entry of the client its cache time
ac:a3:1e:c3:63:78  10.1.1.2  0       3m:20s
00:1a:1e:00:b1:40  10.1.1.1  0       5s
(10.1.1.58) (config) #show arp
Protocol    Address        Hardware Address    Interface
Internet    10.1.1.8           00:16:ea:f0:f0:3e    vlan10
Internet    10.1.1.2           ac:a3:1e:c3:63:78    vlan10
(10.1.1.58) (config) #show user
Users
    IP           MAC            Name     Role           Age(d:h:m)  Auth  VPN link  AP name            Roaming   Essid/Bssid/Phy                  Profile       Forward mode  Type  Host Name
10.1.1.8    00:16:ea:f0:f0:3e            authenticated  00:00:00                    ac:a3:1e:c3:63:78  Wireless  ARPCHECK/ac:a3:1e:b6:37:92/a-HT  default-open  tunnel
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 01:31 PM
Updated by:
Labels (1)
Contributors
