Cisco Jabber not working on Aruba when NAT is enabled.
Symptoms
Why is Cisco Jabber not working on Aruba when NAT is enabled?
This article is valid for Aruba controllers and OS versions.
Diagnosis
1. There is no issues in the connectivity b/w the IP phones, and Cisco call manager.
2. Call can be initiated and the bell goes to the phones.
3. the Phone whose traffic is natted cannot hear anything. If other phone is not natted, he can hear.
Solution
Cisco Jabber doesnt support NAT. Please refer to the document below:
http://www.cisco.com/en/US/docs/voice_ip_comm/cupc/8_6/b_jabber_RN_mac.html#reference_82EE281DF54A421AB6361FC77C2CB55D
Cisco Jabber is not compatible with Network Address Translation (NAT); it cannot use Simple Traversal of UDP through NAT (STUN), Traversal using NAT (TURN), or any other NAT-traversal scheme.
Cisco Jabber must be running through a VPN connection to traverse NAT."
1. We need to disable the NAT on the Aruba.
2. If NAT is necessary, we much make sure that there is a tunnel so that Jabber is not Natted.
Cisco Jabber is not supported over NAT.
Version history
Revision #:
1 of 1
Last update:
‎06-01-2014 02:04 PM
Updated by:
Labels (1)
Contributors
