Cloud activation key for Aruba OS switches
MVP
MVP
Q:
How can we find the cloud activation key for Aruba switches?
A:
We can use the following command to find the cloud activation key :
Aruba# show activate provision
 Configuration and Status - Activate Provision Service
 Activate Provision Service   : Enabled
  Activate Server Address      : device.arubanetworks.com
  Activation Key               : LKMNOPAB
The above command applies to the following switches:
Aruba 2920 Switch Series—WB.16.02.0012 or later
Aruba 2930F Switch Series—WC.16.02.0012 or later
Aruba 2540 Switch Series—YC.16.02.0012 or later
Version history
Revision #:
1 of 1
Last update:
‎03-21-2017 11:45 AM
Updated by:
Comments
Guys, any idea about why activation key is missing on the switch and how can I get it? I'm trying to register a 2930F to Central but the switch doesn't have the Activation Key. See command output below:
w2930F-8G_# show activate provision
Activation Key : Not Available
sw2930F-8G_#
Hi Ivonne,
Show activate provision shows activation key in the switch only when it  has successfully contacted activate
Please provide me the following information:
1. Is the clock reflecting correct time on the switch ?
2. Do you have DNS server configured on the switch ?
3. What is the firmware running on the switch ?
4. Attach the output for :
show log -r
thommy88
I have the same problem with an 2530-24g.
1. Is the clock reflecting correct time on the switch ? -> yes
2. Do you have DNS server configured on the switch ? -> yes
3. What is the firmware running on the switch ? YA.16.04.0009
Keys: W=Warning I=Information M=Major D=Debug E=Error ---- Reverse event Log listing: Events Since Boot ---- I 12/18/17 11:34:11 04611 job: Job Scheduler enabled I 12/18/17 11:33:58 05101 amp-server: AMP server configuration is disabled due to first configuration. I 12/18/17 11:33:57 05226 activate: Successfully resolved the Activate server address device.arubanetworks.com to 104.36.249.201. I 01/01/90 01:00:45 05225 activate: Loading security certificates and synchronizing time with NTP. I 01/01/90 01:00:45 05224 activate: Zero-touch provisioning enabled; connecting to Aruba Activate server to provision system. I 01/01/90 01:00:45 03783 dhcp: DHCP server did not offer all the DNS parameters on Primary VLAN I 01/01/90 01:00:45 00025 ip: DEFAULT_VLAN: ip address 192.168.100.110/24 configured on vlan 1 I 01/01/90 01:00:45 05177 ip: Setting IP address 192.168.100.99 as default gateway. thank you, thomas
thommy88
I´m getting the following error.
W 12/18/17 15:31:15 05602 activate: EST provision with activate server failed because of not-authenticated. I 12/18/17 15:31:14 05226 activate: Successfully resolved the Activate server address device.arubanetworks.com to 104.36.249.201. W 12/18/17 15:30:52 05602 activate: EST provision with activate server failed because of not-authenticated. I 12/18/17 15:30:51 05226 activate: Successfully resolved the Activate server address device.arubanetworks.com to 104.36.249.201.
But unter device inventory the switch has the status "subscribed"
regards, thomas
lxavier
I have the same problem on switch model 253048G J9772A:
HP-2530-48G-PoEP(config)# show activate provision
HP-2530-48G-PoEP(config)# show version
Image stamp:
/ws/swbuildm/rel_venice_qaoff/code/build/lakes(swbuildm_rel_venice_qaoff_rel_ve
nice)
Dec 22 2017 14:21:07
YA.16.05.0004
819
Boot Image: Primary
Boot ROM Version: YA.15.20
HP-2530-48G-PoEP(config)# show time
Wed Jan 24 17:06:53 2018
HP-2530-48G-PoEP(config)# show ip
Internet (IP) Service
Default Gateway : 10.1.1.254
Default TTL : 64
Arp Age : 20
Domain Suffix :
DNS server : 8.8.8.8
VLAN | IP Config IP Address Subnet Mask
DEFAULT_VLAN | DHCP/Bootp 10.1.2.36 255.0.0.0
HP-2530-48G-PoEP(config)# show log -r
W 01/24/18 17:08:04 05602 activate: EST provision with activate server failed
Can you help me?
If the activation key is not available you have to execute the following command first.
#activate provision force
Then the activation key will be available, you can check with the "show activate provision" command.
Br.,
Zs
