Do we have an out-of-band management interface on Aruba Mobility access switch?
Environment : This article applies to all Mobility Access Switches running a minimum AOS version 7.1.0.0
Yes, we do have out-of-band management interface to access Aruba Mobility access switches, Out-of-band management involves the use of a dedicated management channel for device maintenance.
The management interface is located above the console port on the rear panel of the Mobility Access Switch. We can configure only the IP address and description for this interface. The management port can be used to access the Mobility Access Switch from any location and configure the system.
We can configure the management port only using the CLI.
((ArubaS2500-48P) (config) #interface mgmt
(ArubaS2500-48P) (mgmt) # description mgmt
(ArubaS2500-48P) (mgmt) # ip address 10.1.0.1 255.255.255.0
(ArubaS2500-48P) (mgmt) # no shutdown
(ArubaS2500-48P) #show interface mgmt
MGMT is administratively Up, Link is Up, Line protocol is Up
Hardware is Ethernet, Address is 00:1a:1e:0c:17:c0
Description: mgmt
Internet address is 10.1.0.1, Netmask is 255.255.255.0
Global Unicast address(es) :
IPV6 link-local address is fe80::21a:1eff:fe0c:17c0
Interface index: 151006025
Version history
Revision #:
1 of 1
Last update:
‎06-27-2014 03:36 PM
Updated by:
Labels (1)
Contributors
Comments
NOT applicable to S1500 series of switches (12P,24P,48P)
