How do I convert a stack port to a normal port on an Aruba Mobility Switch?
Environment        This article applies to all Mobility Access Switches running a minimum AOS version 7.3.0.0 and Above.
Answer                By default some ports on the Aruba Mobility Switch are configured as stacking-port. For example 1 port of S1500 and 2 ports of S2500 are configured as stacking-ports. We can convert those ports from a Stack port to a normal port and vice versa.
Use “show stacking interface“ command to find the interface configured as stacking-port
(ArubaS1500-12P)  #show stacking interface
stack1/1
stack1/1 is administratively Enabled, link is Down, line protocol is Down
Speed: N/A, MTU: 9224 bytes, Link flaps: 0
Last update of counters:        0d 00:00:00 ago
Last clearing of counters:      0d 00:00:00 ago
Link status last changed:       0d 00:00:00 ago
Statistics:
    Received 0 frames, 0 octets
    0 pps, 0 bps
    0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 error octets, 0 CRC frames
    0 multicast, 0 unicast
    Transmitted 0 frames, 0 octets
    0 pps, 0 bps
    0 broadcasts, 0 throttles
    0 errors octets, 0 deferred
    0 collisions, 0 late collisions
Delete the stacking interface as below and use "show interface brief " command to verify the port
(ArubaS1500-12P) (config) #delete stacking interface stack 1/1
(ArubaS1500-12P) (config) #show interface brief
Interface  Admin   Link  Line Protocol  Speed/Duplex
GE0/0/0    Enable  Down  Down           N/A
GE0/0/1    Enable  Down  Down           N/A
GE0/0/2    Enable  Down  Down           N/A
GE0/0/3    Enable  Down  Down           N/A
GE0/0/4    Enable  Down  Down           N/A
GE0/0/5    Enable  Down  Down           N/A
GE0/0/6    Enable  Down  Down           N/A
GE0/0/7    Enable  Down  Down           N/A
GE0/0/8    Enable  Down  Down           N/A
GE0/0/9    Enable  Down  Down           N/A
GE0/0/10   Enable  Down  Down           N/A
GE0/0/11   Enable  Down  Down           N/A
GE0/1/0    Enable  Down  Down           N/A
GE0/1/1    Enable  Down  Down           N/A
stack1/1
Statistics:
    0 pps, 0 bps
    0 pps, 0 bps
Version history
Revision #:
1 of 1
Last update:
‎06-30-2014 12:27 AM
Updated by:
Labels (1)
Contributors
