How to check OSPF neighbors in MAS?
Environment  :  OSPF used as routing protocol
(Abi-Labport-uplink-Router) #show ip ospf neighbor
OSPF Neighbor Table
Neighbor ID  Pri   State      Address     Interface  Dead Time    Uptime
10.17.0.2    1     FULL/BDR   10.17.0.2   vlan10     00h:00m:39s  13w1d 18h:14m:44s
10.17.0.1    255   FULL/DR    10.17.0.1   vlan10     00h:00m:32s  13w1d 18h:14m:45s
Can also check the OSPF database information with the below command.
(TAC-Labport-uplink-Router) #show ip ospf database
OSPF Database Table
Area ID   LSA Type  Link ID     Adv Router  Age    Seq#         Checksum
1.1.1.1   ROUTER    10.17.0.2   10.17.0.2   643    0x80001903   0x92b4
1.1.1.1   ROUTER    10.17.0.1   10.17.0.1   60     0x80001127   0x53b4
1.1.1.1   ROUTER    10.17.0.5   10.17.0.5   662    0x80004c8e   0xb21f
1.1.1.1   NETWORK   10.17.0.1   10.17.0.1   1620   0x800010dc   0xb20b
Version history
Revision #:
1 of 1
Last update:
‎07-10-2014 03:15 PM
Updated by:
Labels (1)
Contributors
