How to check in 11ac mesh logs about the updates on Mesh topology to the Controller?
Environment- 11ac Mesh Topology updates in 6.4.3
Answer- Once  mesh connection is established, mesh topology information is sent by Meshd to the controller.
The logs for the same can be found in mesh ap debug logs. Below is a sample log for the same:
[904]1969-12-31 16:01:04.293 meshd_send_topology_update: parent 6c:f3:7f:7c:6d:31, portal 94:b4:0f:2b:be:f1, chan 161, offset 0, tx_rate 173, rx_rate 6, uptime 23
[904]1969-12-31 16:01:15.862 Received a action frame 3/2 from 6c:f3:7f:7c:6d:31, len 30
[904]1969-12-31 16:01:27.335 meshd_set_link_cost: Using forward RSSI for mac: 6c:f3:7f:7c:6d:31, fwd-rssi: 74, rev-rssi: 0. (max_rssi: 38), link-cost(cH):400
[904]1969-12-31 16:01:27.336 meshd_set_link_cost: Using forward RSSI for mac: 00:24:6c:5a:82:88, fwd-rssi: 64, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:01:27.336 meshd_set_link_cost: Using forward RSSI for mac: 6c:f3:7f:a8:95:30, fwd-rssi: 55, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:01:27.336 meshd_show_neighbors: skip parent 6c:f3:7f:7c:6d:31 in potential list
[904]1969-12-31 16:01:27.336 meshd_set_link_cost: Using forward RSSI for mac: 94:b4:0f:2b:be:f1, fwd-rssi: 79, rev-rssi: 0. (max_rssi: 38), link-cost(cH):400
[904]1969-12-31 16:01:31.342 reselection_candidate: accepted 00:24:6c:5a:82:88. Reach: 1, rssi: 64, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:01:31.342 reselection_candidate: accepted 6c:f3:7f:a8:95:30. Reach: 1, rssi: 55, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:01:31.343 meshd_rejecting_children: 94:b4:0f:2b:be:f1 rejecting, no_more_children: TRUE, subtree_full: FALSE, recovery: FALSE
[904]1969-12-31 16:01:31.343 reselection_candidate: rejected 94:b4:0f:2b:be:f1. Reach: 1, rssi: 79, cluster: <Meshtest_CopperShieldCage>, n->channel: 161
[904]1969-12-31 16:01:31.343 meshd_metric_start_reselect: found 2 reselection candidates for domain Meshtest_CopperShieldCage, channel 161
[904]1969-12-31 16:01:32.344 reselection_candidate: accepted 00:24:6c:5a:82:88. Reach: 1, rssi: 64, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:01:32.344 meshd_set_link_cost: Using forward RSSI for mac: 00:24:6c:5a:82:88, fwd-rssi: 64, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:01:32.345 meshd_path_cost_compare: initialise first time to 00:24:6c:5a:82:88, path-cost(cH): 1600
[904]1969-12-31 16:01:32.345 reselection_candidate: accepted 6c:f3:7f:a8:95:30. Reach: 1, rssi: 55, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:01:32.345 meshd_set_link_cost: Using forward RSSI for mac: 6c:f3:7f:a8:95:30, fwd-rssi: 55, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:01:32.345 meshd_path_cost_compare: NEW link best (delta: 0). Old 00:24:6c:5a:82:88, pc(cH): 1600, RSSI: 64 (GOOD), hops: 2. New 6c:f3:7f:a8:95:30, pc(cH): 1300, RSSI: 55 (GOOD), hops: 1
[904]1969-12-31 16:01:32.345 Old: metric offset 0, path_cost 8, node_cost 0, cmp_adjust 3, link_cost 500, total path cost 1600, old poor 0
[904]1969-12-31 16:01:32.345 New: metric offset 0, path_cost 4, node_cost 2, cmp_adjust 2, link_cost 500, total path cost 1300, new poor 0
[904]1969-12-31 16:01:32.346 meshd_path_cost_compare: OLD link best (delta: 5). Old 6c:f3:7f:7c:6d:31, pc(cH): 1200, RSSI: 74 (GOOD), hops: 1. New 6c:f3:7f:a8:95:30, pc(cH): 1300, RSSI: 55 (GOOD), hops: 1
[904]1969-12-31 16:01:32.346 Old: metric offset 0, path_cost 6, node_cost 2, cmp_adjust 0, link_cost 400, total path cost 1200, old poor 0
[904]1969-12-31 16:01:32.346 New: metric offset 0, path_cost 4, node_cost 2, cmp_adjust 2, link_cost 500, total path cost 1300, new poor 0
[904]1969-12-31 16:01:32.346 meshd_metric_complete_reselect: no worthwhile improvement. curr-PC-cH: 1200, curr-RSSI: 74, best-PC-cH: 1200, best-RSSI: 74
[904]1969-12-31 16:02:03.408 reselection_candidate: accepted 00:24:6c:5a:82:88. Reach: 1, rssi: 65, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:02:03.409 reselection_candidate: accepted 6c:f3:7f:a8:95:30. Reach: 1, rssi: 54, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:02:03.409 meshd_rejecting_children: 94:b4:0f:2b:be:f1 rejecting, no_more_children: TRUE, subtree_full: FALSE, recovery: FALSE
[904]1969-12-31 16:02:03.409 reselection_candidate: rejected 94:b4:0f:2b:be:f1. Reach: 1, rssi: 79, cluster: <Meshtest_CopperShieldCage>, n->channel: 161
[904]1969-12-31 16:02:03.409 meshd_metric_start_reselect: found 2 reselection candidates for domain Meshtest_CopperShieldCage, channel 161
[904]1969-12-31 16:02:04.410 reselection_candidate: accepted 00:24:6c:5a:82:88. Reach: 1, rssi: 65, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:02:04.410 meshd_set_link_cost: Using forward RSSI for mac: 00:24:6c:5a:82:88, fwd-rssi: 65, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:02:04.411 meshd_path_cost_compare: initialise first time to 00:24:6c:5a:82:88, path-cost(cH): 1600
[904]1969-12-31 16:02:04.411 reselection_candidate: accepted 6c:f3:7f:a8:95:30. Reach: 1, rssi: 54, cluster: <Meshtest_CopperShieldCage>, channel 161
[904]1969-12-31 16:02:04.411 meshd_set_link_cost: Using forward RSSI for mac: 6c:f3:7f:a8:95:30, fwd-rssi: 54, rev-rssi: 0. (max_rssi: 38), link-cost(cH):500
[904]1969-12-31 16:02:04.411 meshd_path_cost_compare: NEW link best (delta: 0). Old 00:24:6c:5a:82:88, pc(cH): 1600, RSSI: 65 (GOOD), hops: 2. New 6c:f3:7f:a8:95:30, pc(cH): 1300, RSSI: 54 (GOOD), hops: 1
[904]1969-12-31 16:02:04.411 Old: metric offset 0, path_cost 8, node_cost 0, cmp_adjust 3, link_cost 500, total path cost 1600, old poor 0
[904]1969-12-31 16:02:04.411 New: metric offset 0, path_cost 4, node_cost 2, cmp_adjust 2, link_cost 500, total path cost 1300, new poor 0
[904]1969-12-31 16:02:04.412 meshd_path_cost_compare: OLD link best (delta: 5). Old 6c:f3:7f:7c:6d:31, pc(cH): 1200, RSSI: 74 (GOOD), hops: 1. New 6c:f3:7f:a8:95:30, pc(cH): 1300, RSSI: 54 (GOOD), hops: 1
[904]1969-12-31 16:02:04.412 Old: metric offset 0, path_cost 6, node_cost 2, cmp_adjust 0, link_cost 400, total path cost 1200, old poor 0
[904]1969-12-31 16:02:04.412 New: metric offset 0, path_cost 4, node_cost 2, cmp_adjust 2, link_cost 500, total path cost 1300, new poor 0
Version history
Revision #:
1 of 1
Last update:
‎04-06-2015 04:20 AM
Updated by:
Labels (1)
Contributors
