How to configure IP Prefix-list on MAS 7.2 and its use-case
Configuration is applied on MAS 7.2 & above.
Prefix-list entry consists of:
  • Sequence number
  • Permit or deny
  • Prefix: represents a subnet or a host
  • Netmask
  • ge and/or le (optional)
  1. Prefix-list is configured to match an exact route or a  prefix range
  2. Prefix-list is used for filtering OSPF routes from being added to the IP routing table
  1. Only prefix-list can be used for distribute-list for filtering
  2. Distribute-list is supported for inbound direction only
  3. Only OSPF intra and inter area routes are filtered
Environment : Typical use case of running OSPF on network to filter the routes.
Network Topology : No Special network topology applied for this configuration for IP-Prefix-list on MAS 7.2
Prefix-list is configured in the IP-profile:
(ArubaS3500-48P) (config) #ip-profile
(ArubaS3500-48P) (ip-profile) #prefix-list PL1 seq 10 permit
(ArubaS3500-48P) (ip-profile) #prefix-list PL1 seq 20 permit ge 27
(ArubaS3500-48P) (ip-profile) #prefix-list PL1 seq 30 permit le 32
(ArubaS3500-48P) (ip-profile) #prefix-list PL1 seq 40 permit ge 24 le 32
The configured prefix-list can be applied as distribute-list for OSPF route filtering (inbound):
(ArubaS3500-48P) (Global OSPF profile) #distribute-list PL1
Above steps explains to configure IP-Prefix list.
Prefix-list can be verified by following CLI command
ArubaS3500-48P) #show ip-profile
ip-profile "default"
Parameter            Value
Default Gateway
Import DHCP Gateway  Disabled
controller-ip        N/A
prefix-list          PL1 seq 10 permit ge 27
prefix-list          PL1 seq 20 permit le 32
prefix-list          PL1 seq 30 permit ge 24 le 32
Distribute-list can be verified by following CLI command
(ArubaS3500-48P) #show router ospf
Global OSPF profile "default"
Parameter          Value
State              Enabled
Distribute-list    PL1
Some of the useful commands to troubleshoot and verify is below.
show router ospf
show ip route
show ip interface brief
show running-config
Check for OSPF profile config.
Version history
Revision #:
1 of 1
Last update:
‎04-08-2015 10:02 AM
Updated by:
Labels (1)
