How to configure RMON in MAS.
Remote Monitoring (RMON) is a standard monitoring specification that enables various network monitors and clients to exchange network-monitoring data with features that meet their particular networking needs. RMON provides network administrators with more freedom in selecting network-monitoring probes and consoles with features that meet their particular networking needs. An RMON implementation typically operates in a client/server model. Monitoring devices (commonly called "probes" in this context) contain RMON software agents that collect information and analyze packets. These probes act as servers and the Network Management applications that communicate with them act as clients. While both agent configuration and data collection use SNMP, RMON is designed to operate differently than other SNMP-based systems:
  • Probes have more responsibility for data collection and processing, which reduces SNMP traffic and the processing load of the clients.
  • Information is only transmitted to the management application when required, instead of continuous polling.
The following groups are supported in this release :
  • Ethernet statistics
  • History control
  • Ethernet history
  • Alarm
  • Event
Configuration Steps :
To enable the RMON service
(ArubaS3500)(config)# service rmon
Configuring RMON etherstat entry
(ArubaS3500)(config)#rmon etherstat 1
(ArubaS3500) (Etherstat index "1") #monitor gigabitethernet 0/0/3
(ArubaS3500) (Etherstat index "1") #owner Admin
Or
(ArubaS3500) (config) #rmon etherstat 2
(ArubaS3500) (Etherstat index "2") #monitor ifIndex.4
(ArubaS3500) (Etherstat index “2") #owner Admin
== Configuring RMON history entry ==
(ArubaS3500) (config) #rmon history 1
(ArubaS3500) (History index "1") #monitor port-channel 1
(ArubaS3500) (History index "1") #samples 10
(ArubaS3500) (History index "1") #sampling-interval 8
(ArubaS3500) (History index "1") #owner Admin
Configuring RMON event
(ArubaS3500) (config) #rmon event 1
(ArubaS3500) (Event index "1") #owner Admin
(ArubaS3500) (Event index "1") #type log-and-trap
Configuring RMON Alarm-profile
(ArubaS3500) (config) #rmon alarm-profile alarm_profile1
(ArubaS3500) (alarm profile "alarm_profile1") #rising-threshold-value 2000
(ArubaS3500) (alarm profile "alarm_profile1") #falling-threshold-value 200
(ArubaS3500) (alarm profile "alarm_profile1") #rising-event 1
(ArubaS3500) (alarm profile "alarm_profile1") #falling-event 2
(ArubaS3500) (alarm profile "alarm_profile1") #sample-type absolute
(ArubaS3500) (alarm profile "alarm_profile1") #startup-alarm rising
Configure RMON Alarm
(ArubaS3500) (config) #rmon alarm 1
(ArubaS3500) (alarm "1") #alarm-profile alarm_profile1
(ArubaS3500) (alarm "1") #monitor gigabitethernet 0/0/4 oid-type in-mcast-pkts-64
(ArubaS3500) (alarm "1") #owner Admin
show rmon etherstat entry <index>
(ArubaS3500) #show rmon etherstat entry 1
RMON etherstat Entry 1 is Active, and owned by Admin
Monitors gigabitethernet0/0/3 from 2-22-2012@03-59-01
Statistics:
Received 0 octets, 0 packets
0 broadcast, 0 multicast packets
0 oversized packets, 0 fragments, 0 jabbers
0 CRC alignment errors, 0 collisions
Number of dropped packet events is 0
show rmon history entry <index>
(ArubaS3500) #show rmon history entry 1
Entry 1 is active, and owned by Admin
Monitors  port-channel1 every 8 seconds
Buckets requested 2, Buckets granted 2
2 sample(s) created
Sample 2:
	Began measuring at 2-22-2012@05-06-52
	Received 1447269 octets, 21438 packets
	0 broadcast, 21398 multicast packets
	Network utilization is estimated at 0 (0%)
Version history
Revision #:
1 of 1
Last update:
‎07-04-2014 02:33 AM
Updated by:
Labels (1)
Contributors
