How to configure, verify and troubleshoot IGMP and PIM-SM functionality
What is IGMP?
The Mobility Access Switch supports Internet Group Management Protocol (IGMP) as defined in IETF RFC 1112 (IGMPv1) and RFC 2236 (IGMPv2). IGMP allows hosts and adjacent routers on IP networks to establish multicast group memberships.
What is PIM?
Protocol-Independent Multicast (PIM) is a family of multicast routing protocols for Internet Protocol (IP) networks that provide one-to-many and many-to-many distribution of data over a LAN, WAN or the Internet. It is termed protocol-independent because PIM does not include its own topology discovery mechanism, but instead uses routing information supplied by other traditional routing protocols such as the Border Gateway Protocol (BGP). There are four variants of PIM, of which theMobility Access Switch supports PIM Sparse Mode (PIM-SM).
What is PIM-SM?
PIM Sparse mode (PIM-SM) explicitly builds unidirectional shared trees rooted at a rendezvous point (RP) per group, and optionally creates shortest-path trees per source. PIM-SM generally scales fairly well for wide-area usage. PIM-SM is useful for routing multicast streams between VLANs, subnets, or local area networks (LANs) in applications such as IPTV.
IGMP Config:
To configure an IGMP profile, follow these steps:
    1.     Configure an IGMP profile under an interface profile.
             (host) (config) #interface-profile igmp-profile igmp1
             (host) (Interface IGMP profile "igmp1") #
     2.     Enable IGMP profile (default is enabled).
             (host) (Interface IGMP profile "igmp1") #no disable
     3.     Assign IGMP profile to a VLAN interface.
             (host) (Interface IGMP profile "igmp1") #interface vlan 2
             (host) (vlan "2") #igmp-profile igmp1
      4.     Verify the VLAN interface.
              (host) (vlan "2") #show interface-config vlan 2
vlan "2"
Parameter Value
Interface OSPF profile ospf-a0
Interface PIM profile default
Interface IGMP profile igmp1
Interface shutdown Disabled
mtu 1500
IP Address
IPv6 Address N/A
IPv6 link local Address N/A
DHCP client Disabled
DHCP relay profile N/A
Interface description N/A
To configure PIM-SIM end to end, follow these steps:
    1.     Create a VLAN.
            (host)(config) #vlan 7
            (host)(VLAN "7") #exit
    2.     Create an interface-profile switching-profile profile to associate with a physical interface.
            (host)(config) #interface-profile switching-profile ip-sp-profile
    3.     Add an access-vlan to set the VLAN when interface is in access mode.
            (host)(switching profile "ip-sp-profile") #access-vlan 7
            (host)(switching profile "ip-sp-profile") #exit
    4.     Associate the interface-profile switching-profile with a physical interface profile.
            (host)(config) #interface gigabitethernet 0/0/0
            (host)(gigabitethernet "0/0/0") #switching-profile ip-sp-profile
            (host)(gigabitethernet "0/0/0") #exit
    5.     Create the routed VLAN interface (RVI).
            (host)(config) #interface vlan 7
            (host)(vlan "7") #
    6.     Assign an IP address to the routed VLAN interface (RVI).
            (host)(vlan "7") #ip address netmask
    7.     Associate the "default" PIM profile with the routed VLAN interface (RVI).
            (host)(vlan "7") #pim-profile default
            (host)(vlan "7") #exit
    8.     Use the router pim command to enter Global PIM profile mode and define the RP address and group range.
            (host)(config) #router pim
            (host)(Global PIM profile) #rp-address group-range
To Verify PIM Sparse Mode follow the method suggested below,
Displaying PIM RPF Information
(host) #show ip pim rpf
PIM RPF Information
Address Nexthop RPF Interface
------- ------- ------------- vlan20
 Displaying PIM Neighbor Information
To display PIM neighbor information, use the following command:
(host)# show ip pim neighbor
Interface Neighbor IP UpTime Expiry
vlan11 07:58:51 08:00:20
 Displaying PIM RP Information
To display PIM RP information, use the following command:
(host)# show ip pim rp
PIM RP-Group Mapping
Group/Prefix RP
 Displaying PIM Mroute Information
To display PIM Mroute information, use the following command:
(host)# show ip pim mroute
IP Multicast Route Table
Flags: D - Dense, S - Sparse, C - Connected, L - Local,
P - Pruned, R - RP-bit set, T - SPT bit set, F - Register Flag
J - Join SPT, A - Assert Winner
(*, 14:20:11 RP flags:
Incoming Interface: vlan11 RPF nbr:
Outgoing Interface List:
vlan22, 14:20:11
(, 14:17:20 RP flags: T
Incoming Interface: vlan22 RPF nbr:
vlan11, 14:17:20
Displaying PIM Statistical Information
To display PIM statistical information, use the following command:
(host)# show ip pim stats
PIM Statistics
Interface Counter Value
vlan11 Rx Hellos 0056
Rx Join/Prune 0000
Rx Join 0000
Rx Prune 0000
Rx Register-Stop 0000
Tx Hellos 0057
Tx Join/Prune 0016
Tx Join 0000
Tx Prunes 0000
Tx Register 0000
Invalid Hellos 0000
Invalid Join/Prune 0000
Invalid Join 0000
Invalid Prune 0000
Invalid Register 0000
Invalid Register-Stop 0000
Version history
Revision #:
1 of 1
Last update:
‎11-04-2014 01:09 PM
Updated by:
Labels (1)
