How to disable Spanning-Tree on Aruba Mobility switches ?
Introduction :
The spanning tree protocol ensures that sensible redundancy in your network doesn't turn into loops. Although it is not recommended, you can turn off Spanning Tree Protocol globally on the switch on occasions like when enabling port level security functionality Loop Protect
Environment :
This article applies to Aruba Mobility Access Switches running a minimum version of ArubaOS 7.0 and Above. The configuration and verification steps mentioned in this article are tested on ArubaS2500 running ArubaOS 7.3.
Configuration Steps :
By default spanning tree is enabled with the mode set to MSTP and it runs on every port. The spanning tree feature cannot be turned off in switches on a per port basis.
(ArubaS2500-24P) #configure terminal
(ArubaS2500-24P) (config) #spanning-tree no mode
Verification :
(ArubaS2500-24P) #show spanning-tree detail
No spanning tree instance exists.
(ArubaS2500-24P) #show spanning-tree vlan all
Note: Extreme care needs to be taken whenever you disable spanning tree because this creates Layer 2 loops within the network.
Version history
Revision #:
1 of 1
Last update:
‎07-08-2014 02:24 PM
Updated by:
Labels (1)
Contributors
