How to disable and enable audit-trail on Aruba Mobility Access Switches
Environment         This applies to all Aruba Mobility Access Switches and OS versions.
In Aruba Switches we do have an option to disable "audit-trail".
Below is the command to disable the same:
(ArubaS1500-24P) (config) #interface gigabitethernet 0/1/0 trusted port
(ArubaS1500-24P) (config) #write memory
Saving Configuration...
Configuration Saved.
(ArubaS1500-24P) (config) #show audit-trail 5
Aug 19 16:22:49  cli[1390]: USER:admin@10.20.25.33 COMMAND:<interface gigabitethernet "0/1/0" trusted port > -- command executed successfully
Aug 19 16:22:53  cli[1390]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfully
(ArubaS1500-24P) (config) #no audit-trail  ====> This will disable audit-trail
(ArubaS1500-24P) (config) #interface gigabitethernet 0/1/0 no trusted port
(ArubaS1500-24P) (config) #audit-trail  ====> This will enable audit-trail
(ArubaS1500-24P) (config) #show audit-trail 10
Aug 19 16:28:15  cli[1390]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfully
Aug 19 16:28:28  cli[1390]: USER:admin@10.20.25.33 COMMAND:<interface gigabitethernet "0/1/0" no trusted port > -- command executed successfully
Aug 19 16:28:32  cli[1390]: USER:admin@10.20.25.33 COMMAND:<write memory > -- command executed successfully
Version history
Revision #:
1 of 1
Last update:
‎11-13-2014 02:32 PM
Updated by:
Labels (1)
Contributors
