How to do mgmt authentication using TACACS in MAS
Here are the CLI commands for enabling TACACS on the S3500/2500. You will need to create the matching device on the ACS server as well.
Creating mgmt auth is not supported in webui.
Conf t
aaa authentication-server tacacs "CORP"
   host 172.16.0.120
   key "prekey"
aaa server-group "TACACS"
auth-server CORP
aaa authentication mgmt
   enable
To trouble shoot please enable following loggings
#conf t
#logging level debugging security process authmgr
#logging level debugging security subcat aaa
# logging level debugging security
# show log security 100
Version history
Revision #:
1 of 1
Last update:
‎06-26-2014 10:35 AM
Updated by:
Labels (1)
Contributors
