How to enable and verify port mirroring on Aruba Sobility Access switch.
MVP
MVP
This requires a Mobility access switch running Aruba OS 7.4 and higher.
We can configure port mirroring on Aruba Switches using mirroring profile. In the example below, we will mirror traffic from G 3/0/8 to the port G 3/0/18.
First we will create a mirroring profile. this profile contains the destination port:
(ArubaS3500-24P-US) (config) #interface-profile mirroring-profile AP-mirror
(ArubaS3500-24P-US) (Mirroring profile "AP-mirror") #destination gigabitethernet 3/0/18
(ArubaS3500-24P-US) (Mirroring profile "AP-mirror") #exit
Next we will map it to a source port. Here we will mirror both ingress and egress traffic:
(ArubaS3500-24P-US) (config) #interface gigabitethernet 0/0/8
(ArubaS3500-24P-US) (gigabitethernet "0/0/8") #mirroring-in-profile AP-mirror
(ArubaS3500-24P-US) (gigabitethernet "0/0/8") #mirroring-out-profile AP-mirror
(ArubaS3500-24P-US) (gigabitethernet "0/0/8") #exit
We can verify it by the command below:
(ArubaS3500-24P-US) (config) #show mirroring
Mirroring Profile Name : AP-mirror
Mirroring Ratio        : 1
Mirroring Destination  : GE3/0/18
Ingress mirrored ports : GE3/0/8
Egress mirrored ports  : GE3/0/8
Version history
Revision #:
2 of 2
Last update:
‎03-24-2017 09:09 PM
Updated by:
Labels (1)
Contributors
