How to schedule a reload of a member switch in a stack.
MVP
MVP
How can we schedule a reboot of a MAS stack member?
Can I cancel a scheduled reboot?
In what different ways we can schedule a stack member reboot?
Aruba Mobility access stack running Aruba OS version 7.4.1.12 and above.
First we will verify the stack:
(ArubaS3500-24P-US) #show stacking members
Stack status: Active, Stack Id: 000b866bd340557d17b2
Stack uptime: 3 days 12 hours 41 minutes 42 seconds
Id    Role       MAC Address        Priority  State     Model            Serial      Location
1     Secondary  00:1a:1e:09:0a:80  Preset    Active    ArubaS2500-24P   BJ0001240   Not Set
3  *  Primary    00:0b:86:6b:d3:40  Preset    Active    ArubaS3500-24P   AU0001346   Not Set
Then we can give the reload command:
A. To reload a stack member 1 after x minutes.
(ArubaS3500-24P-US) #reload 1  in 2
 Reload on memeber 1 is scheduled in 2 mins from now
 Do you want to continue(y/n)? y
 Your 1 member in the stack will restart after 2 mins
B. To reload a stack member at a given time:
(ArubaS3500-24P-US) #reload 1 at 13 3 1 26
Above command will reload the stack member 1 on 26th of first month at 13 hours 3 minutes.
On the console of rebooted switch, we can see:
Shutdown processing started
Syncing data...done.
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
3:<7>sd 0:0:0:0: shutdown
3:<7>ppe 0000:01:00.0: shutdown
3:<0>Restarting system.
3:.
3:<2>Performing hard reset...
CPBoot 1.0.38.0 (build 38162)
Built: 2013-04-24 at 04:59:52
1024MB DRAM init, XLS CPU, 64bit channel pair mode
DDR2 DRAM running at 533Mhz
DRAM:  Total = (0x40000000) 1024 MB
POST:  Memory test: Physical 0x00000000 - 0x10000000 - quick test
       Memory test: Physical 0x10000000 - 0x40000000 - quick test
       PASS
CPU:   XLS208, rev. A1 Clock: 733MHz
CPLD:  rev: 2.4 (0x2.4)
ispPAC:  rev: 1.6
SMP:   All 8 cpus successfully started
Board: 24 port Amarone with PoE
PCIE:  RCx4 mode
Inven: primary inventory is OK
POST2: System Voltages
       PASS
PCIE1: Link Up. (PhyUp=1 DatLnkUp=1 PwrMode=0 LtssmState=17)
       Aruba DPE (PCIE-DevId 0xDEB0)
       BAR1(64M) @ 0xC0000000 (phys 0x60000000)
       BAR0( 1M) @ 0xC4000000 (phys 0x64000000)
PoE:   OK - Ports remain disabled
Net:   xls_gmac0 [PRIME], xls_gmac1, xls_gmac2, xls_gmac3
Boot:  Primary bootflash partition
Reboot code: 0:2b:20:42:58
Hit any key to stop autoboot:  0
booting system partition 0:0
USB:   USB 2.0 started, EHCI 1.00scanning bus for devices... 2 USB Device(s) found
       scanning bus for storage devices... max USB Storage Device reached: 1 stopping
1 Storage Device(s) found
1 blocks read: OK
Loading image 0:0........................................................................................................................................................................................................
Booting image...
Signer Cert OK
Policy Cert OK
RSA signature verified.
Aruba Networks
ArubaOS Version 7.4.1.2 (build 52793 / label #52793)
Built by p4build@lesbos on 2015-12-01 at 23:12:21 PST (gcc version 3.4.3)
Copyright (c) 2002-2015, Aruba Networks, an HP company.
         <<<<<    Welcome to Aruba Networks - Aruba S2500-24P    >>>>>
Performing CompactFlash fast test...  Checking for file system...
Passed.
Reboot Cause: User reboot (0x86:0x78:0x402b)
Initializing TPM and Certificates
TPM and Certificate Initialization successful.
PoE firmware [Ok]
Starting Console Session
Retrieving Configuration ...
(ArubaS3500-24P-US)
User: admin
Password: ********
(ArubaS3500-24P-US) #show version
Version history
Revision #:
2 of 2
Last update:
‎03-29-2017 11:53 AM
Updated by:
Labels (1)
Contributors
