How to switch between Primary and Local Switches in Aruba Stack
Question: How to switch between Primary and Local Switches in Aruba Stack?
There are times when user may want to gain access to the actual/local member rather than be redirected to the primary, such as bringing up a dormant member or need to add/delete stacking interface(s)
Following key combination can be used to gain access to the local member:
Press ESC + CTRL + L (for “L”ocal)
When required task has been completed, following key combination can be used to exit and return back to the primary:
Press ESC + CTRL + R (for “R”eturn)
Version history
Revision #:
1 of 1
Last update:
‎07-02-2014 02:15 PM
Labels (1)
Contributors
